Not that anyone in particular is following this ... but for the record:
This clock seems very sensitive to resistance from the mechanism. For example, when working on the "arresting finger" (or what I call "tine") that holds back the minute, it caused the motor to stop functioning, so that I had to pull the chain to restart. The OP had mentioned the tine being bent. I don't know how much straightening was done originally, but when I got it, it was bent at the tip. This allowed the clock to flip, but I think the way it was bent put more strain against the tiles. (I'm pretty sure it's getting bent when running backwards (see above post). Anyway, now that it's bent back I think it's putting less resistance on the tiles.
Considering how sensitive this clock is, I'm also thinking that the mechanism actually needs oiling. Sort of like how a clock with brass works needs to have the points oiled. There at lease a couple metal to metal places where the plastic gears (through a steel axle - or what clock people call the "arbor") contacts a metal part of the clock frame. So... I'm going to let it run tonight then mayby try oiling tomorrow.
