Hello, I recently picked up a Panasonic RC6700 clock with a faulty motor. Upon opening it, it seems all the gears have become worn or cracked, and I doubt I can ever fix those. Does anyone know where I could get a suitable replacement motor? It seems to be a normal-looking gearmotor, so there’s probably a usable substitute somewhere. I would just need to figure out the RPMs of this motor
Panasonic RC6700/Tamura motor replacement
Are you sure of that model number? I thought that the RC-6700 had an LED readout.~ Mackey Site Administrator
Update: I've given it some time and have some new thoughts/theories.
This thing, while in good physical shape, will need a lot of work to get going.
Every neon is broken/burned out so I will have to change all of those.
Based on the condition of the mechanism and the silicone covering where the motor bearings would have been, I'm guessing someone at some point tried to put an oil into it that harmed the plastic. Theres a random piece of metal stuck over the motor as well like a mounting clip, but its clearly a random torn piece.
I watched the TFM-C660/770W video and saw that these do in fact share the same motor. Is there any way to tell what motor one might have based on a serial number or similar?
Thanks
