Bodet flip clock
  • dlong90210
    • Feb 2020
    • 2
    Bodet flip clock
    I believe that this is made by Pierre Bodet only number on it is a patent number 3834151 it is 41 inches long and 12 wide and very heavy need schematic does not work wondering if batteries are bad any help?
  • Jon_Gargoyle
    • Sep 2019
    • 57
    Welcome to the forum! I don't know a great deal, but is it possible that this is a "slave" clock and therefore needs a "master" clock to work? At that size, it seems likely it was installed in a public area, banking hall or large office/factory, so it might very be a "slave" unit. I'm sure some of the others, with greater knowledge, will add more to this, but they will also probably ask you if you have any more photos, particulary of the inside of the unit.
      That is a massive flip clock, would be great to get that going.
      If it runs on batteries they're going to be big ones, maybe SLA's (Sealed Lead Acid)
      The only information I could find on the Bodet patent # is here:
      https://patentimages.storage.googlea.../US3834151.pdf
      • eathan21th
        • Jan 2016
        • 116
        Maybe you can refer to the following article.
        Hallo Flip clock fans, is it anybody over there who can help me with following issue, please? I bought Bodet clock BT 659 some time ago and I would like to use it as a slave clock for my Brillie mother clock. Brillie mother clock distributes 30 seconds impulses with aternated polarity of voltage. I can use voltage from 1,5 V to
