I have a new flip clock with a tuning fork, is it normal that it makes all this noise? I think I'll put it in an isolated place or I'll turn it off because otherwise I'll become crazy. I attach a file (please listen at maximum volume to have an idea...).
Does a tuning fork clock make so much noise? X_X
I have a new flip clock with a tuning fork, is it normal that it makes all this noise? I think I'll put it in an isolated place or I'll turn it off because otherwise I'll become crazy. I attach a file (please listen at maximum volume to have an idea...).Tags: None
Mine was quite noisy, hummed at about 300 Hz
The case itself seems to act as a resonator because the motor and mechanism are almost inaudible when running out of the case.
I cut the noise down a lot by putting 4 small rubber O rings between the mechanism and the base.
see https://www.flipclockfans.com/forum/...opal-t7-repair
