Robert J (@flipclock_nl) and I have talked about making some sort of knock off of the Howard Miller flip clock. This would, of course, require obtaining some acrylic tubing or cylinders. Additionally, since I have recently and very fortunately come into ownership of an original Howard Miller Flip Clock - I was wondering about replacing the cylinder. In my case, someone seems to have had this in the sun, there is a dip at the top. Additionally there has been some yellowing.
Well. I've learned a little about this stuff. You want casted not extruded acrylic tubing. The casting is able to produce high optical clarity (which is what we want of course).
I purchased some extruded stuff (only about $20 for a foot of it including shipping) to ensure the sizing was correct and also learn how to cut this stuff properly / squarely.
The Howard Miller takes a 3.25 inch outer diameter 1/8 inch thick (3 inch inner diameter) tubing. The one I bought fit properly but it was no where near the optical quality needed (I'm going to use this stuff for flip clock stands). I learned that you need a saw with high tooth count (the more the better). I got a carbide tipped 12 in blade with 92 teeth for my Dewalt Miter saw (them blades is high dollar). I needed to be able to squarely cut this stuff. It worked great.
But here's the problem.
The stuff I need:
This would be $235 total with shipping and tax.
Crazy!
I would have 4 other feet to use and I could make blanks for either upcycled clocks or to see as replacements for Howard Miller clocks I guess.
But over 200!!
Any thoughts?
Maybe I shouldn't go for perfection.
NOTE: I am in communication with the company that sells the stuff I need. It's possible they will work with me. This remains to be seen.
The stuff I need:
- High optical clarity
- Lightweight
- UV stabilized; resistant to weathering
- Provides dimensional stability
- High impact resistance
- Maximum temperature: 200°F
Crazy!
But over 200!!
Any thoughts?
