A very simple radio-alarm clock. Don't know why, but I like it
Would be neat if the dial on the front did the tuning as well as switch the frequency band. Alas it does not work that way. The dial only does the tuning and there is a separate switch for the frequency band.
The little label in the middle is covering a hole that could be used for another dial. Maybe the same body is also used for another model.
Confusing mix of languages here. The label on the bottom maybe explains how that happened.
This clock needed some work, but nothing major:
- lubricated the motor to get that going again,
- cleaned potmeters and switches,
- fixed the alarm (some spacer ring was missing),
- improved the wiring (some connections were insulated by tape which did not look original nor safe to me),
- cleaned and lubricated the push buttons to get these working properly again.
