Hello, I have an RC-6015 that I am working on that is making a pulsating sound in-between stations. It sounds like a high pitched alien message, from high to low over and over again. When a station is selectrd the noise goes away. Any suggestions on what to test on this one?
Pulsating Noise Panasonic RC-6015
Tags: None
- Translate
Here is a YouTube video I made of the noise:
- Translate
Electrolytic capacitors in the audio or RF sections could be deteriorating, leading to instability. Look for indications of leaking or swelling at the top. Test them with a capacitance tester if you can.- Translate
Problem solved. The pulsating was caused by a laptop power cord plugged into the power strip the clock was plugged into.- Translate
