This Copal clock 602 belonged to my boyfriend. He was very fond of it. He died about a year ago. it reminds me of him so I want te keep using it. The clock works fine but I can't adjust the time. One of the knobs is missing. I can turn it with a screw and so adapt the day. But not the hour. Do I need to pull to make it change the time? Or is there another way? I will try to find someone to replace the knob.But I don't want to risk messing it up.
Copal model 602
I just emailed you. But I'll put it here too. I'm pressure sure the setting is just like the 601.
The knob (when present) should be pulled gently.~ Mackey Site Administrator
- Likes 1
Nice clock and worth restoring!
I have one too that is also missing the left knob. As it needs to be turned counterclockwise it has a left handed thread. A skilled person with the right tools may be able to replicate it. An alternative I can suggest is to look for an old windup alarm clock. I found one with a knob with the correct thread in a thrift store. The handle though does not fit the case so I still need to do some work.
