Finally, after much work, I've completed the restoration of the Panasonic RC-6493.
This was a fairly difficult clock to repair. The video below goes into some detail about the process and is recommended for anyone considering trying to replace the lights.
One thing I did not mention in the video, is the over engineering of this clock. I learned that the wires to the lights is mil-spec high temperature, silver plated copper strand 24 awg wire. The pvc tub covering is rated to over 220 degrees F. I would recommend anyone replacing the lights with an original type light retain this wire (it's expensive stuff) and take the time to solder in the light to the existing wire.
Hope the video helps someone.
