Feel free to browse all you want! But you will have to register
before you can post: click the "Login or Sign Up" link at the top right, then select "Sign Up". NOTE: After you register you must check your email and confirm your registration.
I had to re-edit this so here we go again. I bought the AC powered LED units from eBay. I then removed the LED portion and added extension wiring. To dim it down I added a 220k Ω / 1W resistor. The rest is obvious from the photos below:
