Hello.
While looking for old devices with vacuum fluorescent display I came across a Copal 602 (wood/black): too nice to be true. There I came home with my first flip clock.
Luck is that it works, maybe it is 10"/hour on the fast side. It misses one of the date setting knobs, but for now I can live with it. The real "problem" is that one palette was found floating free inside the case, and the attached picture shows the damage.
Are there chances that I can cut a thin piece of plastic, superglue it in place and return the flap into its original position? Can this be done without unfastening the mechanisms?
Last but not least, the attached knob does not come off: is it supposed to unscrew in anti-clockwise direction, right?
Thank you for reading.
Paolo - Italy
(working with electronics)
[clocks designed and built: with Nixie tubes, with vintage HP LED display]
Paolo - Italy
