Im trying to restore 2 of these flipclocks and the issues Im stucked with are the following
the one is nearly ready. I replaced the filament light with a small amber LED (which I connected to the DC power from the radio)
The synchro motor works well (even though a little bit noisy), the radio works pretty well, but as always the mechanical properties of the actual flip mechanism has its issues after so many years
This issue manifests in the leafs not falling always correctly. The problem comes around the 45 minute and keeps on up until 03-05 as you also can see in the first photo
the second clock has the usual problem of the plastic copal gears (a copal gc-2464 itself). The plastic gear attached to the brass gear of the motor has been "smoothed out". (photo2)
My aim is to open the cover and check the broken gear. Find a replacement or 3d print one. my FDM 3d printer is to thick for this kind of a job but I hope I can get my hands on something more detailed. But I dont have a non violent way of opening the cover as the cover has no screws, and it is pressfitted into place (photo 3)..
is there a way to open it without violating it beyond repair? I dont have another copal motor so I dont want to destroy this
thanks
thanks
