Hello, I have a Lloyd's stereo Multiplex flip clock with a possible stripped gear. The motor spins freely, but the clock also shows the seconds which rolls. Their is a peg on the second's part that turns a gear to flip the tile. But, the smallest gear inside the metal case that is attached to the motor is stripped. Is there any way a piece of rubber could be attached to the motor wheel to create tension and turn the gear? Have any of you solved this problem without replacing gear?
Any tip is appreciated! Thanks!
