Caslon 201
  • Caslon 201
    I just picked up this great little Caslon 201. There are several scratches on the black case. Any ideas what I can use to polish these out, safely? Thanks in advance!
    automotive polish will do the trick. i use this..and never had a problem
    • #3
      Thanks, I'll try it!
      • #4
        These Caslon clocks accept polishing very well. The plastic used is exceptionally durable. They will even take light sanding (150-400-1000 plus in series works very well). But I wouldn't sand unless absolutely necessary. I'm hooked on Meguair's Plastx clear plastic polish. I get great results on both clear plastic and colored plastic.
        Click image for larger version  Name:	plastix.jpg Views:	1 Size:	15.1 KB ID:	3482
        • #5
          Excellent, thanks!
